Lowest W/O cutting
F
Lowest W/O cutting
F
frogwood
What is the lowest possible drop on an 88-98 fullsize w/o cutting the frame for a c notch.Strictly bolt on so it can be changed back to stock.20 in wheels will be used on the truck as well so id like to avoid clearence issues if possible.
jmn444's avatar
jmn444
not 100% sure, but i don't think you'll even come close to clearance issues w/o notching the frame. BUT, you CAN change back to stock after notching the frame, you don't have to cut the bed to do it. If for no other reason you can go lower and still have some suspension travel rather than banging the axle against the bumpstops or frame all the time...
F
Franks69chevy
you can do a 4/6 with a bolt on notch with out cutting through the bed with 20s, it can still be put back to stock
rockboy
mine is only cut a little and it lays hard on 20's j/k
bdroppeddak's avatar
bdroppeddak
its alittle hard, but i didnt cut anything on mine either, just had to massage a couple spots..... its all in who is doin it.
