Chevy/GMC Trucks \  22s on rear of bd fullsize must I narrow the axle?
views 161
replies 4
Pa Pa Dragger   +1y
Edited: 3/19/2006 6:44:32 AM by mojingle
I have a 3 1/2 " body dropped 90 Chevy fullsize with an Exstensive Metal Works 2 link. I have read some guy's say they didn't have to narrow the rearend with 22s on the rear and some say they did. The wheels are 22 x 9 with a 5 1/2 " back spacing. Will I have to narrow it with these wheels and if not what are the tire size you guys are running on these un-narrowed 22" rear setups to tuck when layed out? I'm keeping the 20s on the front so I'm not concerned with the front at all. Thanks for any help
bdroppeddak   +1y
my wheels have 6.62" of backspacing (35+ mm offset), and tuck fine with no rubbing. another problem you will have is with that setup, the panhard bar will shift your rear end. dont forget about that.
bagged2200   +1y
yep chris is right i had the Exstensive kit on mine and i end up taking it off when i went with 22's the bars was like a 1/8" form my tires but of course the narrow my rearend 2"s on each side , my wheels sit far enough in i still have the factory wheel well lip i would go with a 4 link thats what i did.
SuperCharged6MT   +1y
i had 22x10 with a 7" backspacing in the rear and it barely made it, so yeah, i'd say your are cutting it close...
Pa Pa Dragger   +1y
Thanks guy's. Exstensive says they have set them up with 22s, I will check it out further.
