I have a 99 burban. I want to be able to lay frame, not a big thing i know, but i also want to be able to still pull my 18ft car trailer with my c-10 on it. It does it now with a 2-4 drop on it with no problem. What bags should i use, 4 link or 2 link,etc...
jblsuburban
I'm baggin a '97 burban used slam specialties 7". The worst thing is no travel room in the rear without cutting the floor. but i think w/o cutting the body will be about 3-4" off the ground. Another bad thing is the giant fuel tank just no room to put anyhting, I tried to relocate but the rear seat pan wont hardly let you do anything. good luck
tealchevy
slams, FOR SURE, use the midrange slams since you will be towing, and you can raise and move the stock tank forward to get enough clearance to lay. If you dont the tank will keep the ass off the ground about 1 inch.
