Cut Springs
clairvoyntlulaby@aol.com's avatar
Cut Springs
Dezavala's avatar
Dezavala
my friend has a 2000 Chevy Silverado single cab... he wants to cut the springs, but we need to know how much cut will drop it how much... 1 coil = 1 inch? or how does it work?
BaggedWagon
1/2 coil = 1" of drop
Dezavala's avatar
Dezavala
thanx for the info
GB
Gangsta Boogie
just buy drop coils. he'll be happy he doesnt have to go spend an arm and a leg for new coils when he wants to sell the truck. It will ride shitty and may squeak because the coil wont seat as securely as a stock spring. that is too new of a truck to destroy the coils when the aftermarket ones arent that expensive.
Low_SST's avatar
Low_SST
i wouldnt worry bags are usually in the future when you start getting lower.
mtm's avatar
mtm
man i don't see why people cut springs. I know it is a cheap alternative to getting low but everytime i have priced drop coils they are like $60 for the set. Do it right the first time and you won't regret it.
GB
Gangsta Boogie
exactly, its even more work than a simple remove and replace with drop coils. and if you do bag it in the future you cant even sell your stock coils to someone else who hacked theirs and wants to go back to stock. also if your state has yearly inspection, you can pass easily. in most states cut coils will not pass inspection.
DougyFrisch's avatar
DougyFrisch
my s-10, one and a half coils got me down to tire meeting fender, couldn't fit my finger between the tire and fender. i say cut em, cause like Joe said, baggin' will soon follow. and trying to sell used lowering spring just ain't as easy as it sounds, just cut yours and scrap em when your done. and honestly, the ride wasn't as bad as people beat it up to be, it rode pretty smoothly. the rear is another story when the only suspension you have and the axle resting on the bump stops
kboring
Yeah, cut them a half a coil at the time until the truck sits where you want it...Keep in mind that it will settle up to an inch after you drive it though
periportfd
Amen
s10
last post by baha +1y
