tailgate
tailgate
s10soolow
I think I might shave my tailgate should I just cut the skin off and weld her up or leave the gate intact and weld away? witch would be beter?
snugglesfon's avatar
snugglesfon
When I had my 2wd bed I just welded the whole tailgate on. Welded a piece of metal in between the rollpan and tailgate and used body filler for the rest.
treylos's avatar
treylos
leave the tailgate intact it will be soo much stronger that way. you can then weld the inside to the bed floor too.
tenagator's avatar
tenagator
use some angle steel and weld it solid. u still may get cracks over time. but anything is going to crack that isnt suppsoed to be done.
s10soolow
thanks
eyekandydesigns's avatar
eyekandydesigns
Edited: 3/25/2006 7:43:17 AM by eyekandydesigns
I would say put in a skin .... they sell them for a reason....I was told by Musso Motorsports here in Las Vegas that they put skins in becasue a tailgate is heavy and even though you weld it in it will have vibrations and eventually crack at the top or more. A skin is closer to the same thickness of your body....I would use a skin. By the way if anybody is interested I have a skin for a 99+ chevy silverado from grant kustoms, selling it cheap, hit me up if your interested.-rj
Low_SST's avatar
Low_SST
yea a skin with a 1x1 box tubing frame to brace the bed and then skin the inside with sheetmetal. thats the best way.
LowKey87
I'm pretty sure they dont make skins for that truck.
TwistedMinis's avatar
TwistedMinis
Grant does make skins for that truck. You just have to use the upper rail from your stock tailgate.
snugglesfon
yeah if you plan on leavin that bed on for a while i would get a skin, less work, I just did mine like that cuz I was going to get a 4x4 bed soon.
