hey guys looking for pics of a 98+ s10 with 20s juiced with 275-60-20 tires for now you know the suv tires. ill eventually get thinner tires but would like some fat tires for now. so i know ill need drop spindles for the 20s to lay im in cali i know the ac is on the right side what else needs moved
I
I-10Hauler
thats a 33" tall tire...not gonna happen
blazenide89
bro ill get the thinner ones later just tell me or show me what all needs moved & where to. im in cali so i gotta keep smog shit ofcourse
I
I-10Hauler
well the way u worded it, sounded like u wanted it to lay now on those tires.
anyway, u will either need to modify your upper and lower arms or get tubulars. notch the frame for tie rods. remove or modify your blower box. tub the firewall. relocate/remove abs, washer reservoir, battery tray, fuse box, coolant reservoir, ecu. get a smaller brake booster, raise wiring harness thru firewall. modify clutch cylinder/linkage if its a manual.
for more details instructions theres tons of threads everywhere for doing this.
