Mazda Trucks \  driveshaft question
driveshaft question
Mazda Trucks Make Specific
views 307
replies 10
following 7
Marshkid1   +1y
does anybody have any pics of a two piece shaft setup? i want to do a two piece driveshaft because i don't want to cut up the cab and i've got stereo equipment in the way
im2lo4ya   +1y
cut up the cab for what, are you layin frame or body dropped, i lay frame with 18's and a one piece and all we notched was the crossmember, still have about 2 inches to the cab
Marshkid1   +1y
the rear is set up for 20s, i don't want to redue a driveshaft if i get bigger wheels
maddawg   +1y
check my profile.
my driveshaft is not stock though,nor is my carrier bearing, it a gm carrier a slip and stub and 2 cv joints.
BK2LIFE   +1y
"the rear is set up for 20s, i don't want to redue a driveshaft if i get bigger wheels"
that makes no sense to me, please rephrase the question
periportfd   +1y
http://streetsource.com/forum/topic.aspx?topic_id=74137&Topic_title=Need+help+getting+knowledge+to+you.&forum_id=16&forum_title=Suspensions
He means if he changes to bigger wheels the suspension will have to travel further to lay the same.
Marshkid1   +1y
hey rudy, how much money did you spent approximately for your whole driveshaft setup? i'm thinking about buying a decent two piece from a junkyard and getting it cut and welded twice, once on each, catco charges 40 a cut and weld, and like 30 for balancing.
maddawg   +1y
i had mine built from scaratch but i can'ttell you how much i paid cuz then everyone will bash me for paying so much.
put it this way .....i got more than one shaft.
periportfd   +1y
Rudy, did you go through Inland?
Marshkid1   +1y
yea, i think i'm gonna be spending alot on a shaft too, just hope i can find a clean one up here in MN. Thanks for the pics Rudy
