check valves
W
check valves
F
fixedtl24
Ok pick up some check valves today for my front Valves. Installed them and they only go up and does not go down. I didn
do_spiderman
Where did you put them?
bagginitdotcom
Sounds like you have them in the wrong place. They need to go either between the fill valve and tank, or between the tee and fill valve.
F
fixedtl24
Yes they are between the tank and the fill valve. I put then on the vavles were the air is coming from the tank.
Low_SST's avatar
Low_SST
i would have to see a pic of your setup to know whats fucked, im thinking its location of valves or wireing.
F
fixedtl24
ok thanks guys i fixed the problem wires were lose.
F
fixedtl24
man with the check valves on it ride better and not as bumpy for the fronts. Will this affect the frame since its more stiff? mean will it push the frame up? I had to get the front frame welded before because it was cracking.
bagginitdotcom
Check valves shouldn't affect how it rides unless you're one of those people that puts full pressure into the front bags to have that "cool" raked look. Otherwise, its probably a figment of your imagination. As for stiffness and pushing on the frame, just keep an eye on it. I can't see it being that much more stiff, if any, so if you've been good on the frame since it was welded, then you'll be fine.
s10
last post by baha +1y
