When Bodydropping
When Bodydropping
stacey4me
when body dropping can I keep the sterring colum connected or should I take it out? also what thickness of a steel should I use for the body drop?Last question what type of rims should I get? Thanx guys I will soon be dragging door
bodydrop99ranger
i left mine hooked up and i use 16ga and rims that up to you
stacey4me
Thanx guys for the response
bodydropped85's avatar
bodydropped85
take it out, it will bind and cause it not let the cab level out. you HAVE to redo your steerin linkage(fi its a ranger anyways).
19ranger88
Does ne 1 have a site with would help me out a lot on bagging my 88 ranger???
clenzer72
www.rangerpowersports.com
lots of info you can use to learn
skruba
i did a 3.5 Bd on my 94 ranger and my steering is bindin up any tips guys on what to do.....makes all kinds of noise seems to be to much of a angle anyone else run into this problem
F
fuller
16gauge...take the column out..i never had any problems with the steering on mine, i swapped out for a tilt wheel and everything worked on my old 95
skruba
hmmmm idunno
bodydropped85
i ahd to put 2 universal joints in mine, one at the fire wall and 1 and the steering gear.
