Chevy/GMC Trucks \  2x3 or 2x4 box tubing...
views 617
replies 15
following 13
974door   +1y
which one should i use on my 93' reg cab to stock floor my tuck. if i use 2x4 will it still be enough to lay rockers if i use 2x3 with it be strong enough to handle 500 h.p. any info would br appereciated
outlawcrewcab   +1y
2x4 will lay rocker 2x3 will hold but be a bit flexable use 2x4 if you plan on high HP
bdroppeddak   +1y
Edited: 3/29/2006 7:59:25 PM by bdroppeddak
use 2x4 regardless, if you use 2x3 as a single rail you will get some flexing issues behind and infront of the cab. you could prolly bodydrop 3 1/2" with 2x4 tubing without cutting into the floor.
974door   +1y
thanx for the info. when you weld it, do you weld the wwhole length of the frame, or just put some pretty good stitch weld in a bunch of places.
bdroppeddak   +1y
you mean puttin the tubin inside the stock frame? i just stitch weld it, like a 1 1/2" weld every 8-10 inches.
Low_SST   +1y
you cut your front clip off, build a frame table, measure the mounting points of your body mounts, tranny etc, and then get cracking on the frame.
bdroppeddak   +1y
thats alot of work though, i did my frame in like 2 weeks for my fullsize, and it still looks clean, and factory-like.
Low_SST   +1y
got any pics of it?
974door   +1y
thanx for all the info fellas.
1los10   +1y
what wall thickness are we talk'n cause i'm think'n of use'n 11 gauge for my back half with about 350 hourses??
