Toyota Trucks \  clutch master cylinder/brake booster
Toyota Trucks Make Specific
views 306
replies 5
tenagator   +1y
some ppl say to angle the clutch master cyl up? that canmnot be done it will still hit the tire. can ppl post pics to prove this? i def have to move mine up with the body drop. im lookin for some pis that show exactlly where it is moved to and what was cut out? as the same for the brake booster. it hnik i have it figured out but i wana make sure.
24HourRoadDotRemoval   +1y
just use the booster out of a metro its way smaller and wont hit the tire later P
insaneautoconcepts   +1y
Metro booster is too small for bigger tires than a 15. for the booster try http://www.finalfab.com
1lonisn   +1y
Locate the clutch master cylinder under the dash. It is all 1 unit. take it out, and you can mount it whereever you want.I think under the dash is the easiest. then just remake the pedal. I didnt have to move my brake booster. I am 3" BD on 18's with a z'd frame. I also had 20's on it and they cleared fine.
tenagator   +1y
well i dont understand how u can move it to under the dash?? to get the push in on the cylinder and all.u didnt have to move the booster? hmm id ont get it my tire will lay right into it. so im gona move it over. i cut otu thte firewall where it moutns thru i cut extra so im gona flip the sheetmetal i cu tout so now it will be farther away form the tire. its not gona be easy to do but ill make it work somehow.i z'd 3/4 and body dropped 2 3/4 also so i dont get how u can run the booster in stock location? i have 18x8 wheels
tenagator   +1y
well i moved the booster over almost 3 inches and moved the clutch next to the frame rail on the floor. took many measuments and tested the push in and extensions and all. should work out fine
