How do I turn a red truck white? photoshop
CIPrez
O.k. Ive tried hue and saturation I can change the color to any color I want but not quite light enough to look white
KEG Media's avatar
KEG Media
try this bro. go to image-adjust-hue/saturation. select red from the drop down menu and move the lightness slider all the way to the right then click ok. if its not light enough for you. duplicate the layer in your layers palete then set it to screen in the drop down menu on the layers pallet. you can also adjust the opactity on that one if its too bright white. after that is done you can go to image-adjust-color balance and then add in some slight blue and cyan to your color to give it a bright white look. i suggest always duplicating your color layer then turning off the original red one so u still have it incase u go to far and need to go back to your red layer for anything. good luck.
crochface's avatar
crochface
i just desaturate it then go to image, adjustments, levels, and ill just brighten it up till it looks right
TrucksHC's avatar
TrucksHC
i do it the same way robbie explained it. desaturate. adjust bright/contrast. multiply layers using screen and/or opacity. then slight color balance. white is the one of the hardest to get right...you're gonna have to mess w/ it a little.
