Interior \  type of fabric
type of fabric
Interior Q & A
views 243
replies 5
following 5
nvrhapy   +1y
i plan i redoing my headliner and some inserts on my doors, i'm going to use the dap contact glue, can i use any type of material? whats the best bang for the buck material and easy to work with, i also plan on throwing in some flame work with foam.
lo75lux   +1y
Tweed or Suede,tweed is cheap but gives the vehicle a "uniquer" look..lol...suede is expensive and gives it a "im rich and can afford nething" type of look....i usin pillow cases for the interior peices in my truck..lol....no,i really dont know but i thing tweed is the shit
nvrhapy   +1y
well i was wondering if the glue will bleed through certain materials, cause i was just going to go to a fabric shop in the area and see what they have in clearance thats a gray color.
2lo4u   +1y
it won't bleed through if applied correctly. less is more with contact adhesive. as far as material I would reccomend using auto or marine grade only.
bbt fab   +1y
spray the glue out of a gun and apply only dust coats so it will not bleed
Madfly   +1y
Tweed will definately be easier to sculpt flames or whatever you want in the headliner. Use 1/4" landau top pad (also called closed cell foam by some) to layout the design on the CLEAN headliner board. Use a hi-temp landau top adhesive type glue. Dap sells a great one for this, and spray both the back of the tweed and the board. It is a contact cement meaning the two will bond together. The glue should be tacky, not wet when you bring the two pieces together. Suede can show bleed thru if the glue is too heavy. One can should be enough for the average board.
