9MM handgun
last-leg@hotmail.com's avatar
9MM handgun
Last Leg's avatar
Last Leg
I own a 9mm Ruger P89 and would like to get it registered, But I kinda want to check the cerial # first....Does anyone know of a website that I can do this at???? Ive looked but everywhere I go you have to be a paid member...
Last Leg's avatar
Last Leg
bump
Bdierks
why would you want to register it?
MIDWEST DRAGFEST's avatar
MIDWEST DRAGFEST
incase he has it with him and he gets pulled over its not wanted in a murder case or somethin
i dont know man i could see what i can find out at work tomorrow tho and see what i can do
low95ranger
take the serial # to the police station and tell them to run it...
Lo94S-10's avatar
Lo94S-10
First of all, where do you live? There are only a handful of states that require handgun registration. Next question would be, who did you buy it from or where? There are certain avenues you should take when buying a handgun "Cash & carry" to protect yourself in instances when you might suspect ANYthing could cause a problem. If you want to have the proper paperwork done, so the pistol is in your name, you'll first need to make sure you can legally possess a handgun, then contact the sheriff, and explain the situation. They will more than likely check the serial # of the pistol, have you fill out the paperwrok as if you were buying the gun, run a call in background check, which will take 5 minutes, and that should be it. Don't quote me on this, for I don't know thw laws of every state, just FL, and now PA. It's a really smart thing to do, to go on your states website and read up on all gun laws if you are a gun owner.
