Dodge Trucks \  caddy tails?
caddy tails?
Dodge Trucks Make Specific
views 364
replies 13
following 9
dodgemanwith20s   +1y
Alright i'm gettin ready to put caddys in my ram...Just wandering if anybody could help me out with wiring them up..I got a 98 dodge ram
BadAssChevillac   +1y
i would go to discount auto, autozone, or GM and buy some wiring harness pigtails and then just splice into ur factory wiring.the pigtails will come with which wire is what. that will probably be the easiest way.im not to sure which type of bulb the caddys take though, i think it might be like a 1157 or 3157, somehting like that.
chevygurly   +1y
are they stock caddy's or LED caddy's from AVS or Custom Classic?
dodgemanwith20s   +1y
the are factory 89-93 Cadillac Deville tailights . also they already came with the factory bulbs and about 5" of the wiring harness still on them... just wandering which wires i need to splice into on my truck to get them to work right?
dragingulfcoast   +1y
all you ahve to do is look at a 88-98some 99 chevys. The colors of the wires are the smace for the running lights brake lights so on so on. You ill have the one little light which is also a running light which you just whire into the running lighs. Then you have to figurs out your wiring harness on the dodge and slice them together. You can get the cloro code for your wiring in a manuelfor your year truck.
chevygurly   +1y
you can tap into your trailer harness...if you have one...we recommend this for people with 99+ chevy's...
Low_SST   +1y
hes got a 98 dodge.
bill brasky   +1y
smace?
dodgemanwith20s   +1y
i guess i'll figure out something... hell it can't be that hard to do?
gimp5561   +1y
get you a test light and a friend to run the brake and turn single sw. it is not that hard at all. where are you at i word for dodge and can help out if need be
