olskoolpup
by running that pressure switch with the built in relay along with a solenoid, you are doubling up a little bit.
you WILL be safer running it through the solenoid since those AZ are a little power hungry, and the relay in the viar p/s are known for failing.
this is how i would do it.
run a 12V switched (ie ignition, toggle inside, whatever) to both the 12V "key on" and 12V "fused" of the pressure switch. run the 12V "under load" to a little post on the solenoid. ground the solenoid as well as the pressure switch(if there is a lead). connect a high current, fused wire to a large terminal of the solenoid, the compressor to the other side.
dont worry about having the high current side of the relay connected to a low current circuit, you are mearly using the realy to trip the solenoid at this point(which takes little current).
also, have your fuse less than 12" away from the battery. the solenoid can be anywhere.
