WHERE TO PUT VALVES AT
MP
mike payne
i was just wondering where to put my valves at on my 86 cheavy c 10,would it be better in the front of the truck,or just mount them on the tank.thanks for helping
LOWSILVERALDO
you wont use as much air if you put them closer to the bags
MP
mike payne
thanks man
MP
mike payne
any one else ireally need every ones opinion i am fixing to hook all my valves up,need to know whats best.....
Twisted Galant's avatar
Twisted Galant
You will use just as much air no matter if you mount them at the tank or at each corner or whaterver. I think setups look alot cleaner when the valves have a dedicated placement. When you open up the hood, trunk, etc. It looks like crap when you se 2 guady ass valves sitting there JUST MY 2 PENNIES
unfadeble's avatar
unfadeble
your valves will be more responsive closer to the bag. Because the valve will open and alow the air to go strait into the bag insted of opeing and haveing to fill the air line all the way from the back of the truck to the bag.
do_spiderman
Edited: 4/5/2006 12:41:12 AM by DO_Spiderman
Edited: 4/5/2006 12:40:54 AM by DO_Spiderman
Mine are in my cab, and the exhaust is run out the bottom of the cab.
I did it that way to keep my valves cleaner and to keep them from freezing. And they never did freeze on me this winter (and its my daily).
2lo4u's avatar
2lo4u
mounting them near the bags will make the bags fill faster. you also have to consider how you are setup in the front, if your inners are removed you may collect dirt in the exhaust valves and moisture from rain.
jmn444's avatar
jmn444
Mine are near the bags kinda... the fronts are about a foot behind the front wheels on the frame rails and didn't have any problems at all thru the winter... it is logical that closer to the bags will use less volume of air too, so if you aren't running a oasis or edc you should consider that. I like the idea of having them in the cab too, just not real sure about the noise level though.
Low_SST's avatar
Low_SST
^ yea my fills are pretty loud, especially with nitrogen in them.
s10
last post by baha +1y
