is it just bagged or bodydropped. most rangers need a positive offset to lay out. what size tire are you running. lots of details are needed to answer this properly.
ok i just bought a set of 18 and 20 for my step side bagged ranger. they are a positve 38 off set which is about 6 inch of back spacing they should fit i will tell you tommorrow if you keep the post fresh. i am testing them in the morning before i have the tires mounted. oh yeah they are a 20x8.5
My boyds are 6 5/8" backspacing and they fit the 4 1/4" bodydrop that I had before. It will be close but i'm pretty sure they would fit. I can still make left turns down, so I have a little room.
Charlie
yup they fit. they are a +38 offset on an 8.5" wide wheel which i think is about 6" back spacing. fit perfect. and tuck under my step side bed beautifully. the 18's up front rub a lil when i turn but it is do able. no prob
