Can you tell me what this is on my engine and how to fix it??
clenzer72
in the pic near the back of the engine is that piece with the duct tape on it. what is it? i guess it's some sort of vaccum...it leaks when the engine runs. how can i fix it and what will it cost?
it's a 3.0
thanks...
ScojoDak
That appears to be a vacuum line to your power brake booster. You should be able to get a new one at any joe blow parts store. Fix it quick. You dont want a serious vacuum leak for very long.
toreadorxlt
can you get a better pic of it? From the angle it looks like its the brake booster vaccum line that is going into the intake manifold.
clenzer72
ask...and you shall recieve...
thatsmydawg's avatar
thatsmydawg
get some heat shrink tubing and melt it right over the broken plastic line
Binary
its not a broken line is broken on the intake side. the nipple or whatever its called is broken.
orangemazdab2000's avatar
orangemazdab2000
JB weld might work.
BadAssChevillac's avatar
BadAssChevillac
yea try that^
bodydropped85's avatar
bodydropped85
pull the upper intake and get a 90 fitting some teflon tape and a barb fitting w/ a hose clamp.
