Isuzu \  Front Bag mounts????
Isuzu Make Specific
views 422
replies 6
following 5
PUPon20s   +1y
Who makes front bag mounts for my 95 pup?
DJ Jiggly   +1y
You might have some trouble with factory made bags for 'pups. I had the factory plates installed and had to keep buying new bags...cause the install shop put em too close to the spindle and they kept rubbin a hole in the bags......watch out for crappy installations!! You might be better off fabbin' em yourself or having someone make them 4 U!! L8r -Jay
PUPon20s   +1y
Yeah, thanks for the advice. I probably will have to make my own anyway if I want to layout on 20's.
PUPon20s   +1y
I found just the person to make them. His name is Larry Echols and he owns Innovative air suspensions out of washoe valley, Nevada. He does some badass work.
mmrcustoms   +1y
check the local shops and tell that the u need ft. upper bag mounts for a torsion bar truck i got mine for like 20 bucks
sundown   +1y
Larry's the man! if he will make these for you they will be right.
On the flips side though, I got my upper mounts from Jason at Suicide doors (torsion kit) and measured/cut them to fit. The bags just clear the spindle ball joint nuts on one side and the frame on the other side.
whynotfab   +1y
Regular old 'Torsion Mini Front Bag Brackets' you can find on most air parts sites, including mine.. just have to be trimmed.
Check out the Sticky also, Jared took some good pics
http://streetsourcemag.com/Forum/topic.aspx?method=reply&topic_id=72380&forum_id=44&forum_title=&M=False&S=True
