Mazda Trucks \  A/C AND HEATER CORE?
Mazda Trucks Make Specific
views 126
replies 3
famlayd   +1y
CAN A 91 MAZDA CAB PLUS BE STOCK FLOOR B/D WITHOUT SACRIFICING THE A/C AND HEATER? I LIVE IN CENTRAL CALIFORNIA AND IT GETS HOT IN THE SUMMER TIME.
madlowmazda   +1y
if you are stock flooring it- then that means you aren't cutting the floor and you are retaining the original floor height- thus a stock floor. So everything stock will fit in a stock floor truck- right? Except- you might have to raises the trans tunnel for a stock floor, right? Well my truck is traditional BD to the rockers and I have stock heater core and room for the ac, although my truck doesn't have ac. It's all in how you cut the trans tunnel. I just left the front part of the tunnel in tack- and cut the rear section of it- this is where the trans gets close to the body. Also- you might want to lower your whole engine trans assembly to clear the hood and to help with trans not hitting the tunnel. I did this on mine- lowered the whole drivetrain about 1/2 inch. Every little bit helps.
time1   +1y
SISSY!
I actually took my A/C OUT! and i live in fresno.
dssur   +1y
yes.
in fact when I did the stock floor on mine, I just left the ac system complete and charged (took the compressor off the motor and zip tied it to the firewall) and yanked the cab off.
