so i put in a factory tach gauge cluster, everything works except for the clock, i checked for blown or missing blank fuses and everything is ok, is there something i need to do, i no it wokrs, i seen it working in the donor truck???
yeah if you dont have a tach cluster standard. the clock will not work I am sure you can wire it up but that would take some work. So just to make clear if you installed a tach cluster in a truck that didnt have one from the factory the clock will not work.
I have a 88 b2200 and added a cluster with a tach and clock. All you have to do is follow thw power from the clock on the circuit board and add a 12 volt power wire in the plug there its pretty easy
The same thing happened with my '87. There are 2 wires missing from the factory harness. I got a Haynes manual and looked in the back where there are the wiring schematics. I then removed the 2 missing wires from thwe junk truck (one clock power and one dimmer)and snapped them into my harness and ran them to power and dimmer.
