Mazda Trucks \  quick question
quick question
Mazda Trucks Make Specific
views 183
replies 10
following 6
lomitsu   +1y
Edited: 4/11/2006 12:51:49 PM by groundbound96
i have navi wheels on my bagged 89 long bed. i havent put the bed on yet will i need to flare the side so the wheels dont rub?
livinlow   +1y
no
dssur   +1y
you will need to redrill your hubs because they have the wrong bolt pattern for a mazda. You can "make" it work, just dont make me follow you down the road.
lomitsu   +1y
the wheels are on and i got the wheels redrilled i just wanted to know if they will hit the bed when draging and driving low
dssur   +1y
great joerb, I should learn to assume less.
I have seen em on planty of bd mazdas, they should fit just fine.
roach25681   +1y
Please explain more about getting the actual wheels redrilled. Ive wondered about this.
lomitsu   +1y
i brought the hub and wheels down to a local machine shop and they just made new holes so that he mazda lug pattern would work.
roach25681   +1y
So basically they just enlarged the orginal holes then?
TwistedMinis   +1y
He said they made new holes. So, from what I have seen, they probably drilled seperate holes in the wheel. Making 12 holes. Like a dual pattern wheel with 8 or 10 holes, just for a Mazda or Lincoln in this case.
lomitsu   +1y
Originally posted by blazedbowtie82
He said they made new holes. So, from what I have seen, they probably drilled seperate holes in the wheel. Making 12 holes. Like a dual pattern wheel with 8 or 10 holes, just for a Mazda or Lincoln in this case.you are correct
