just curious if its destrucive to anything to roll in my 300 layed out, nothing rubs but its independent rear RWD and im sure the axels are tweaked in some way? anybody have words of wisdom?
I
impala_631
i would be more worried about tire wear, looks like its negative camberd when its laid
juicedwagon
its not the camber as much as it is the toe when its laid out. and yet you will eat tires but just dont ride like that all the time. you will know when you need to bring it up a little, when you feel bad for your car cause you hit a bad bump.
shvd64cdy
CV AXLES ARE PROBOBLY GETTING ABUSED PRETTY BAD LIKE THAT
BB
bill brasky
Also it depends on how fast you are going....If it is cruising speed you will more than likely be ok. Interstate speed you better stop by the morgue and size yourself up for a toe tag to save your fam. from some grief when your time comes.
Low_SST
Originally posted by HypnoCustoms
i would be more worried about tire wear, looks like its negative camberd when its laidnegative camber...on a bagged vehicle...oh the horror.
