88-98 What to do about clutch resevoir?
bradspaulding@metaldyne.com's avatar
Balzout Sparkin's avatar
Balzout Sparkin
I've got a 92 that I'm in the process of layin frame on 22's. Everything has gone fairly smoothly so far. Only problem I have ran into so far is the clutch resevoir. The tire is rubbing the line coming out the bottom of it and I don't have the 2" spindles on it yet. So has anyone else ran into this and what have you done to fix it?
Balzout Sparkin
Pics would be freakin' sweet and Thanks in advance!!
bdroppeddak's avatar
bdroppeddak
i junked the auto and put a 5spd in my chevy. i used a clutch pedal assembly from an 86 isuzu truck and modified it to use a gm master cylinder, then mounted it under the dash.
Balzout Sparkin
BUMP
Thanks cris, truck is sweet.
