Body work and Paint \  flushing shavings opinions
Body work and Paint Q & A
views 123
replies 2
crippled4life   +1y
alright i know the cleche' whatever work works,and i know how i do it i want to know when u guys shave things do u like to cut a piece exact and weld ,grind and use little bondo or do u like to cut the piece bigger than weld it to the back,grind,glass,bondo?
86nissan720   +1y
i work at a bodyshop and some of the body guys that work with me say to put a piece behind it, but that will use more bondo in the end. i cut a piece the same size and welded it in somewhat flush then used some bondo. just take your time and try not to warp the door.. it sucks to fix.
KEEF   +1y
Cut the area(lip) out first then flush plate with thickness of metal gap around it for weld to fill. Tack till solid grind smooth and if u do it right it wont require much filler at all. I usually skim mine with short strand kitty hair kock that down real quick then 2 part putty. Also before i start the filler work i epoxy prime.....
