Clutch Master Cylinder
sweetnsilver
Well I have started to cut my truck for the body drop and I'm working on making room up front. Anyway the mock up rim and tire I'm using is about the size of 20 with a small tire. It's gonna hit the Clutch master for sure and I need to tub the firewall. My question is what are you guys doing with you clutch master? I have some ideas but I want to hear some others. Russ I know you have some advice on this one....Tim
bdroppeddak's avatar
bdroppeddak
on mine i used a wilwood reverse swing pedal assembly with both a clutch master cylinder, and 2 brake master cylinders. i know my chevy is a chevy, but what i did on it was got the clutch pedal assembly from my buddies 86 isuzu truck, modified it to mount a chevy master cylinder to it, then installed it under the dash. the older isuzus use a cable clutch.the pedal assembly is standalone, and bolts to the firewall, and it pulls a cable through the firewall, so you just make it push a master cylinder, instead of pull a cable.
dssur's avatar
dssur
yeah cris has the right idea. If 20's are what you desire, You are going to need to move it inside the dash.
So you are finally cutting huh? Slow down speedy! It was only like two months ago when I came over and checked it out! No need to rush...
Ryan has that reverse swing stuff, find out where he got his.
flameds10(tyler)'s avatar
flameds10(tyler)
just get an automatic like i did!!!!!
Dragthatchit's avatar
Dragthatchit
my buddy ryan, that russ is talking about, he used a under dash brake and clutch kit form willwood, about 500 bucks, but very nice kit!! Worked real well in his yota
dssur's avatar
dssur
haha I think Tim knows Ryan with the yota Ryan...
And I'll bet you remember tim if you think about it.....
Dragthatchit
shut up russ, had a brain fart there for a minute, i didnt realize that was tims goofy ass postin that, lol!!! My bad!!!
bdroppeddak
500 bux wow i got mine for 360 bux with 3 master cylinders.
Dragthatchit
well 500 was just a general figure, hes had it for a year, sorry dude couldnt remember the exact price!!
dssur's avatar
dssur
haha what gave it away, his screen name TIM, his locaton of WICHITA, or that he drives a MAZDA?
haha I'm just breaking your balls because your truck is cooler than mine.
