relocated clutch master cyl. wont work need help asap
royaltz2001@aol.com's avatar
tenagator's avatar
tenagator
ok i relocated teh cltuch master cylinder to the lower floor. tha shaft for the cyl is not attached to the bottom of the pedal arm, when we bled it out and filled with fluid its way to hard to push due to no leverage. so its not going to wrk. so how have u guys did urs? i got soem responses in the past but i need pics of both the engine area and under the dash. i need to solve this isuue quick and figure out where to move it to now? im think of the stock location but making the mounting surface angled up to clear the tire. im really stuck i need soem help herethansk guys
dubrocker04's avatar
dubrocker04
why can't you just modify what you've already done so that you do have leverage?
tenagator's avatar
tenagator
Edited: 4/16/2006 9:19:44 AM by tenagator
well i dont know where to start. im gona try figureing something out. im sure ill come up sith something to get some leverage. right now im basically pushing straight in on the cylinder and its way to hard to push. i jus want to knwo if theres a easier way? i may jus try to angle everyhting up in the stock location.peoples ay to move it up so it goes thru the wiper cowl area. i cant see how u can do this? thres not enough room under the dash to move the pedal assembly up that far. and how can u possibly seal it it water tight? i jus cant picture it
the501clique
bro just cut the part of the firewall that it bolts up to out move it up an inch or two or sink it back into the firewall and weld it there then patch up the hole. there really isnt much to it tha hardest part was keepin the water out dont be shy with the caulking gun
nicoloyd's avatar
nicoloyd
I want to see some pic's of exactly what your doing.
tenagator's avatar
tenagator
well i got a cylinder and a reservoir form a civic. since there seperate it worked out good. i used my pedal assmebly cut it up made all new brackets and hangers and bolted the cylinder right to the assembly, bolted it up close to stock location then ran the line thru the firewall to the slave. teh reservoir for it is in the wiper cowl area. the line runs down thru the top of the firewall into the cylinder, i had to mod the pedal cut it and moved it up alil to get it even with the rest. but it works fine , so figured it all out. witht he help of civic parts
time1's avatar
time1
pics??
TwistedMinis's avatar
TwistedMinis
Where are your pics Tim? Lol.
time1's avatar
time1
HaHa....just posted them up in the "rockers" forum...it should hit the front page soon!
F
fyrexp2001
I moved mine up 2-3 inches right below the cowl and angled it up so it clears the 18s and the stock arm from the pedal works on it... ive been driving it with no problem
