Mazda Trucks \  89 b2200 Front Rotor help..
Mazda Trucks Make Specific
views 402
replies 9
following 7
powang   +1y
Im changing the front rotors and pads on my 89 b2200. I took the hub/rotor unit? off the truck. Then i took the 6 bolts off that went from the rotor to the hub. I figured it would just seperate from there, but no go. How do i get the rotor off the hub? It looks as if its 3 peices...hub-rotor-back of hub? Do they have to be pressed apart? Or is mine just rusted together?
Also, once i get it off, and put back together how much grease should i pack in there? (for the bearings)
thanks again for your help..Dee
powang   +1y
Anybody have any ideas??
Thanks again..
mazdalow   +1y
Hit it with a hammer and see if that will break the rust and get it apart.
mazdalow   +1y
anyways if you bought new rotors it should have came all together brand new..
dssur   +1y
they are seperate, mine just fell apart. Hit em with a bigger hammer.
powang   +1y
I did buy new rotors, but mazdas are differnt then say hondas, I cant just take the two screw's off and pull the rotor. You have to take the rotor/hub assemble off, take the 6 bolts off..then..i dunno. I could beat it with a hammer but i dont want to damage the bearing, if its supposed to be pressed apart. If its supposed to be "hit" apart i just need to know the "trick"
Anyways thanks for your help..anybody else changed theres before?
Laters
Dee
TwistedMinis   +1y
I had to beat mine out on my truck. Most hub and rotor setups are the same or very similar, so just beat it apart.
powang   +1y
Russ thanks for your help. So they are 3 peices correct? hub(were the lugstuds go),rotor,and the backside whatever its called.
So long as i know they arent pressed together i dont mind beating them =)
Thanks againDee
TwistedMinis   +1y
They should beonly two pieces. The piece on the backside should be part of the hub. Basically beat the old rotor off the hub.
dssur   +1y
Thanks againDee
mine were just two pieces, the hub and the rotor. I had to change them when I put on the 4 lug hubs from mike brott (which were gorgeous) Mine literally just fell apart, but it was a california truck (no rust or corrosion anywhere.
