Stock 95 axle width? Tuckin 20's???
nevadahiroller@yahoo.com's avatar
PUPon20s's avatar
PUPon20s
Does anyone happen to know that width of a stock 95 pup rear axle. I am wondering if an early 4x4 yota axle is narrower than a stock isuzu. The stock Yota rear axle (pre-85) I believe is 55 inches wide. Would swapping in this rear axle help me tuck 20's any easier without having to convert to toyota five-lug all the way around????
bobby7m
r u trying to stay with the six lug? i used all toyota stuff from a 89 i believe. i think the rear was 2 inches narrower than the stock isuzu one. good luck
dragalac's avatar
dragalac
i ll sell you a narrowed 2000 fullsize rearend i cut to fit under my truck
F
FrameLayN88
I don't know off the top of my head what the length difference is but I have 20's my my 88 all around with all stock parts exept the air ride and 2" spendles!
FrameLayN88
Isuzu
PUPon20s's avatar
PUPon20s
I would like to keep my six lug sh!t because i already have a set of six lug 20's for the truck. Out of curiosity...what kind of work is involved in converting the front of a 95 pup to toyota 5 lug????
bobby7m
I basically had custom arms made to fit with Toyota balljoints. From the balljoints outward everything is toyota. Even BYC or most places can build ou ones for the Isuzu that will have ends to match up with the toyota balljoints. give it a shot if you change your mind.
draginzuzu
All I did was swap rotors Used the isuzu bearing inside and out and yota hubs and so far everything is peachy no one has said if this is the wrong way yet
draginzuzu
i have a 95 rodeo axle and a 89 pup axle if you want me to go measure them, There both in the bushes. LMK
Related Discussions in Isuzu
