Air Ride Suspensions \  switch box qutestion!!
Air Ride Suspensions Q & A
views 130
replies 7
following 5
turboh22aakkord   +1y
ok guys... i finally got my car all wired up and holding air and stuff... the only problem im having now is figuring out which switch does what! I just have the standard pre-wired 10 switch switch box.. but i cant figure out which switch does what... ive only got a 5 gal tank with 1 AZ compressor.. so i dont have a ton of switch play.. so its been hard to figure out what swich is which... does anyone have a diagram or a picture or soemthing that would help me out? thanks guys...
TC29720   +1y
go to suicidedoors.com man, they've got a wiring diagram there for ya
Stock Sucks   +1y
If your looking at the end with the wire its like i typed out below the pic, when wired with this way
front up/back down(seesaw) all up/downfront up/down right frontback up/down left frontdrivers side up/down right rearpass side up/down left rear
Stock Sucks   +1y
front up/back down(seesaw)_______all up/down
front up/down___________________ right front
back up/down_____________________ left front
drivers side up/down_____________ right rear
pass side up/down_________________left rear
might be a little easier to picture it
turboh22aakkord   +1y
thanks man... so if im looking at the switch box with the lead wire facing me.. the first switch on the right side is the pankake switch? (all up/all down?) thanks again...
turboh22aakkord   +1y
well, i went home last night and tried using those switch combinations... and they didnt seem to work.. i couldnt even find the pankcake switch at all... does anyone have any other help for me?? thanks!!
bagged300mondubs   +1y
front up/back down(seesaw)_______all up/downfront up/down___________________ right frontback up/down_____________________ left frontdrivers side up/down_____________ right rearpass side up/down_________________left rear
^^ this is correct!
thsese are the switches, if the cord is facing you!
turboh22aakkord   +1y
^^ this is correct!
thanks man... i guess im just going to have to go through my switch wiring again and figure shit out.. thanks though.
