Chevy/GMC Trucks \  i need a bullet proof 4 link desigin
views 599
replies 14
following 9
eff1fiddy   +1y
i have 2. 20 inch bars and 2 .24 inch bars i have a longbed reg cab 90 chevy 3/4 ton 8 lug i was thinkin 2 parrelell foward and 2 trianguleted towards the diff bacwards is that good or should i run all 4 bars/ backwards? what is tha easiest way 2 set up everything as far as a c notch before ?or?after tha 4 link is tacked up i have over tha axle air bag mounts is that ok 2 use or should i make bhind the axle mounts 4 tha air bags i have dun complete air rides on my truxs b 4 but i need 2 kno about tha chevys i have only done fords . what about tha carrier bearing is that goon have 2 b lifted or shimmed up 4 ne reasons ne response is better than none thanxz
imagine if there wasnt ne haters and run with it
NaviGangsta   +1y
use kevlar mounting brackets
95FullSiZE   +1y
Edited: 4/18/2006 7:44:53 PM by 95FullSiZE
HAHa. First run all the bars one direction like all forward or all backward, second u cant weld to the diff so u will have to run all links on the axel shafts so if u do an all reverse 4link i would do bags infront and under the axel prolly.
eff1fiddy   +1y
whut is a kevlar mounting brackets and how do u get tha bags under tha axle?
bagdb2200   +1y
Personally I would run all 4 bars forward....
bdroppeddak   +1y
run all bars forward, and the diff shouldnt be welded on, we made a wishbone 4 link for a customer, and bent up a tube to go around the diff and weld to the axle tubes, that way the point of the wishbone can still be over the axle so you wont have driveshaft clearance problems.
tenagator   +1y
def do all forward 4 link. reverse is not the way to go. i did a ton or reasearch on it. reverse will work fine but it jsut isnt right according to all the info i got on it. so here u go read this so i dont get a whole ordeal on reverse setups.
http://www.streetissuecustoms.com/reverse4.html
lot sof good info here http://www.streetissuecustoms.com/tech.html
eff1fiddy   +1y
thanks alot 4 tha help whut u do with tha gas tank if u go all fowrd
86nissan720   +1y
relocate it to the bed
eff1fiddy   +1y
in tha bed aint relly an option how bout maybe notching it or whut can i rasie or make a new x member
