do I have to put anything else over epoxy primer before I paint,am using acrilic-enamel,can't spell.I see all this other stuff ,sealer primer etc.Am used to just primer and paint but all this new stuf comes out .thanks
I
idragmazda
You dont have to put anything over epoxy, you can go straigh to paint and clear. But if you wanan do bodywork and shit, you'd lay down the epoxy then do the filler/bodywork over that, then lay down a high build (to get all the small scratches out) then either go straihg to paint or one more coat of epoxy. the epoxy is non sanding and its not high build so you wont be abale to get out those sanding scratches easly.
