Wheel Questions \  Whos is runnin with 215/35/20's
Wheel Questions Q & A
views 2239
replies 16
following 9
FLATPRO   +1y
I need to know from the top of the tire to the bottom the exact inches... my 18s w/ 215/35/18s are 23 1/2 inches would 20s/215/35 make it 25 1/2 ?????
tukin19   +1y
Stock Tire - 215/35R18 >Search Tires Tire 1 - 215/35R20 >Search Tires Section Width: 8.46 in 215 mm Section Width: 8.46 in 215 mm Rim Diameter: 18 in 457.2 mm Rim Diameter: 20 in 508 mm Rim Width Range: 7 - 8.5 in Rim Width Range: Unrecognized tire size. Overall Diameter: 23.92 in 607.56 mm Overall Diameter: 25.92 in 658.36 mm Sidewall Height: 2.96 in 75.184 mm Sidewall Height: 2.96 in 75.184 mm Radius: 11.96 in 303.78 mm Radius: 12.96 in 329.18 mm Circumference: 75.14 in 1908.5 mm Circumference: 81.43 in 2068.3 mm Revs per Mile: 869.5 Revs per Mile: 802.4 Actual Speed: 60 mph 100 km/h Speedometer1: 55.3 mph 92.2 km/h Speedometer Difference: - Speedometer Difference: 8.362% too slow Diameter Difference: - Diameter Difference: 7.72%
FLATPRO   +1y
Wow... i doubt now I cant fit them...
bdroppeddak   +1y
do they make a 215/35/20? if so who makes it?
FLATPRO   +1y
umm I think Nankang
bdroppeddak   +1y
as far as i know they dont make a 215/35/20....
chunky_thunder   +1y
Edited: 4/23/2006 5:48:41 PM by chunky_thunder
i am running a 225/30/20....not sure about a 215/35
jmurphy   +1y
I run a 225/30/20 and it is 25.3 Nankang
Lockone   +1y
No one makes a 215/35/20. The smallest out at the moment is the 225/30/20 Nankangs like we put on Chunky's ranger. The total is 25.31 inches. Nankang NS-IIs run 138ea and Nitto NeoGens run 158ea plus a little shipping. L8R
redranger92   +1y
Same here up front and 245/35/20 on the rear.
Red
