Air Ride Suspensions \  lower arms for hydraulics
Air Ride Suspensions Q & A
views 130
replies 6
following 5
onelow96cs   +1y
anyone out there make lower arms for hydraulics?
the501clique   +1y
just use the ones made for bags and weld a powerball to the lower bag plate
jeebus @ mmw   +1y
yea, or you can weld a spring cup to the bottom plate also.
The arms im having made by barley legal fabrication is making them setup to have a powerball welded to the bottom.
taylor
onelow96cs   +1y
if i lost my spring and moved to the powerball set up would i lose lift? im running 8" in front now but swaping out for 6" soon
ProHopper   +1y
yes you will lose lift, when working with powerballs you will be running coil-over instead of coil under thus the loss in lift due to the coil being around the cylinder instead of on top of it, you may gain some drop from it and safety but thats about all
4uh8rs   +1y
im using the art arms with powerballs no springs.i get plenty of lift with 8 inch cylinders.i am body dropped on 22s and clear the front tire at full lift
onelow96cs   +1y
thanks alot for the help guys i assumed coil under was the only way to go with hydro set up in the front im still new at this.
