arms
arms
crippled4life
so when i get the tubular control arms is it as easy as just bolting them up with no mods to lay 20's?thanks
Low_SST's avatar
Low_SST
no its never that easy.
dragn168's avatar
dragn168
you'd have to get your arms first......................then youd have to weld some tube on there any way have fun with that its easier to just make them lay on stock arms just refer to the sticky on this forum
crippled4life
weld tube?where?getting the arms is not the problem ive got that covered
shortrodeo
Typicaly when you get custom lower arms they are trangle shaped and the front bolts into the stock lower arm bracket and the back has some weld on tabs that you need to weld to the frame... this back part with the tabs eliminates the need for the front radius rods.
Project_Overkill's avatar
Project_Overkill
where you getting arms from? i need a pair!
Related Discussions in Isuzu
