Air Ride Suspensions \  front suspension
front suspension
Air Ride Suspensions Q & A
views 141
replies 8
following 5
jbaker72157   +1y
Wondering if anyone has any idea how to get a little more lift out of the front. I have a colorado and I just got done with the body drop and its not getting as much lift as I would prefer, Ive been tossing around the idea of switching the front to hydraulics for more lift, but im not sure, any suggestions?
detached   +1y
i know slams will get you another inch maybe two compared to an air lift bag. dont know what else to tell you bro besides cantilevering the front also?
jbaker72157   +1y
how would i got about cantilevering the front?
jbaker72157   +1y
bump
nathansmc   +1y
ok, the front is basicaly a "mechanical advantage" cantilever anyway. the closer to the pivot point, the higher it will go. look at moving the bag further inwards, if needed channel into the chassis a tiny bit.... fair bit extra lift this way
jbaker72157   +1y
bump
nathansmc   +1y
????? are you just waiting for someone to do it for you??? there is one or two good ideas here... run with one of them
zombieDatsun   +1y
I second what DATSLO said. Move the bag closer to the pivot point. Other than that, you'll have to look at your other options.
get twisted   +1y
check to see if the bag is fully compressed when aired out maybe the bag brackets are spaced out to far then you could just put a spacer under the bag to compicate for the bag not being full compressed just a thought
