4 link tabs
fast1a2004@yahoo.com's avatar
4 link tabs
eff1fiddy's avatar
eff1fiddy
if i am using heim joint ends on da 4 link bars should i weld the tabs really close to the heim joints like side by side or should i get spacers and make the tabs a little wider? ne 1 put an 8 lug on da ground with 22s?
BIGRIGZ
you should use a "misalignment bushing" it's like a spacer for each side of the heim joint but, it will allow the heim to deflect and twist etc. you would end up welding the tabs noticeably wider when you use those misalignment bushings. A google for the misalignment bushings will show you what they look like.
eff1fiddy's avatar
eff1fiddy
thoese bushings r metal or rubber i looked them up but i dont kno y they wouldnt of sent them with the 4 link do u kno where 2 get them fast
BIGRIGZ
http://www.redrock4x4.com/shop/categories/228_244.html
http://www.midwestcontrol.com/catdisplay_short.php?pg=228
Here's a couple of links to show you what they are and what they look like. Probably if you look in your local yellow pages you can find a listing for a store that sells racing equipment. Lots of those performance shops that sell dirt track or auto racing stuff sell them. You may even be able to find them at a good hardware store?
Low_SST's avatar
Low_SST
i would try to get them so the tabs are 3" apart so if you ever deicide to rock bushing ends you can still use the same tabs.
eff1fiddy's avatar
eff1fiddy
good looking out people thats what im talkin about im waitin 2 get better pics 2 post thank u again
