f**kin side skirts
reflector_collector1@yahoo.com's avatar
f**kin side skirts
parasiteEC's avatar
parasiteEC
I bought a body kit for my honda and cant get the side skirts on. I was wondering if anyone has ever put some spyder side skirts on a Honda before?
unluckys10's avatar
unluckys10
not tryin to be an ass..but good luck finding anyone on here to help..probably gonna get bashed for wanting a body kit...
HS
hybrid showoff
civic or accord? i used to have them on my accord. who did you buy them through and what seems to be the problem? are the fiberglass or plastic. most kits need to be adjusted and modifyd to fit eventhough they are said to be a direct bolt-on.
parasiteEC's avatar
parasiteEC
it is a 96 civic hatch and the vent on the back hits the pinch weld under the door. do you have to cut that off or what?
parasiteEC's avatar
parasiteEC
oh before anyone want to bash on me for havin an import i also have a bagged s10 keep that in mind when reading this
HS
hybrid showoff
yea, your going to want to trim that down in the back, i usually wrap a piece of masking tape around the fiberglass where im cutting first and cut through the tape, that way fiberglass particles are flaying everywhere. then i use a dremel with a cut off wheel on it. take your time cutting it and keep the speed on the dremel on setting 2 or 3, if you try to go too fast with the cut off wheels they will break and fly into your face and that hurts.
jcordova's avatar
jcordova
95% of all bodykits don't fit, they all require some sort of bodywork. The cheaper the kit the worse it will fit. Even good expensive kits will warp by the time it reaches your doorstep.
IMO that is the biggest negative about cars. Sure you can keep you stock ones but a lot (not all) of stock bumpers look like ass too.
parasiteEC's avatar
parasiteEC
SO I NEED TO TRIM DOWN THE PINCH WELD ON THE CAR? THANKS FOR THE HELP
HS
hybrid showoff
nah, man dont go gettin all grinder happy on me now, your gunna want to trim down the inside of the SIDE SKIRT, where the vent is. the inside of that vent should be a good 2" wide or 1.5" but your gunna want to trim that down to about 3/4" of 1/2".
pootytang
don't forget the safty glasses! fibreglass in the eye will end ya up in the emergency room. happened to 2 of my friends in the last month.
