Mazda Trucks \  I NEED HELP WITH MY RIM OFFSET!!!!! PLZ!!
Mazda Trucks Make Specific
views 87
replies 4
cheech136   +1y
Edited: 4/26/2006 12:26:28 PM by cheech136
The wheel i want is a 25 offset but i have to run a 1 inch wheel adapter which should put me around 1 or 2 offset the rim size is 18x8.5 if ne ones has done this or know if i will be able to tuck my wheels under my fender plz respond.. thank you. my truck is a 1999 mazda b2500 which i think is a 20 offset centered
original rim size is 18x8.5 with a 25 offset and i need to use the i inch adapter
Low_SST   +1y
a 18x8.5 rim with a 1" spacer thats already +25 will be about +50
cheech136   +1y
Originally posted by Low_SST
a 18x8.5 rim with a 1" spacer thats already +25 will be about +50no the rim is a 18x8.5 inch rim with a 25 offset and with the 1 inch spacer it will be a 0 offset and i need to know if i can tuck those
dssur   +1y
you added backwards!
If someone tells me what they have on their mazda that DOES fit I can tell you if what you want to do will fit.
Or you can ask in the ranger forum, because thats what your truck is. Probably a lot more help over there, we are mostly six lugger importers over here.
Low_SST   +1y
its been a long day of finals and projects my brain is shot
