removing fuel pump
removing fuel pump
cruisinlowS10
you guys got any tips for removing the fuel pump out of my gas tank? 86 s10.
I
ixenn
drop that tank and its simple.
cruisinlowS10
the tank is out of the truck. just never pulled a pump and dont want to screw anything up
I
ixenn
should just have a lil ring holding it on the tank that you have to manuver.
V
vinnysmini
There should a ring holding the pump onto the tank. The ring should have some notches or grooves in it and just use a small screwdriver and hammer to tap the ring. Turn the ring either to the left or right to unlock the ring and then the pump should slide right out.
cruisinlowS10
thanks guys i got it out. forgot the #1 tool....wd-40. thats all it took and i was set
