I see pics of mazdas with all of the stuff on the right side removed and looking clean. how do I and what will I need to replace to make this happen on my 90 2200.
thats it? put a weber carb on, throw the octopuss away and let her rip? sounds too easy. but I figure you should know. So once I put a Willwood master cylinder in the only thing under the hood will be the engine.
I see 76 people have looked at this post with no more answers so i guess your right. what is the part number of the weber i need to get? Also will I have to run a header?
A weber 32/36 is recommended. If you don't want to run a header all you have to do is plug the PAIR injection pipes going into the exhaust with bolts.
Keeping the computer may have some advantages if you want to add some slight flexability to the weber but most of the advantages only help when driving in winter.
