90 chevy 3/4 ton the frame is not even to weld c notch flat it looks like i can trim it down flat and weld in my notch but i know people have done it b 4 so whats the best way?
streetsweeper1
The best way to notch that frame is to trim it flat, you are right about that. But I would def reinforce the straight sides of the C-frame around the notch on that truck. the notch has a tendency to put too much stress on the adjoining points and will sometimes crack depending on how hard you are on your frame. you might think about building a whole new rear clip. It's hard to make those wavy C-frames look neat.
eff1fiddy
so if i went all out and did a whole clip whuts the best way 2 join the new tubing frame to the actual stock fame where should i cut it right after the cab?
streetsweeper1
I would cut it all the way up to the front frame clip.
eff1fiddy
im lookin just 2 do the rear half thogh how would i attach the new frame to the stock frome whuts the strongest ways
draggindimes
slide the new rails into the exsisting frame. and weld everything you possibly can. Then box it in and weld some more
granth
eff1fiddy
thats a coo way all the way by the fire wall i am trying 2 maybe start rigth behind the cab and just have 2 raise the bed accoordingly ..ne body got ne more pics of either projects or finiched frame rails or at leat rear clips? thanxz
granth
IFCustoms has god knows how many back half build pics.
