compound cuts in box tube or bend
brian@illusivefabrications.com's avatar
slammedxonair's avatar
slammedxonair
Edited: 5/2/2006 9:48:36 PM by slammed x on air
im building a frame that needs some compound angle cuts in the 2x3 all i have is a normal chop saw can anybody help. also how much does art morrison charge to bend tubeing
slammedxonair
nobody on here knows where how i can do this or get some custom bent 2x3 rails all i need is for underneeth the back seats of my explorer back to the hatch
Pneufab
http://autoweldchassis.com/spec.ivnu
for bent tubing
or you can just make a posterboard template for the compound cut, trace it to your tubing and cut it out with a plasma or cutoff wheel
t
E
ebman
You could cut a "v" shaped notch out of the tubing and bend it and weld it back together.
___________ ______________
___________\/______________
I would make sure the weld is strong and then gusset both sides after it is done.
slammedxonair
ya i dont really wana v it if i dont have to
bdydrpd97
On an episode of Monster Garage, When they are building the semi truck chopper they take some 2x4 metal and do small v shape cuts about1/2 inch to get a bend and weld all the cuts back up to get a bend to go to the semi wheel for the front of the semi truck chopper. If this is even what you are trying to do I don't know. But I would imagine you could look it up on the internet to see a picture of it. Hope this helps
s10
last post by baha +1y
