TwistedMinis
Edited: 5/3/2006 10:59:00 AM by blazedbowtie82
Originally posted by Turbo32
why not just figure out you're ride height with the leafs still intack, notch you're frame, throw you're link setup on and then take the leafs off.
sounds awhole lot easyier then what you guys are talking about and the leafs will keep everything centerd and true.
Depended on the link setup it may pull the axle forward too much. You've seen those truck that have the rear wheel about 2" forward. Lol.
I just took a shitload of measurments when I did mine. It wasnt hard. I used a plumb bob to fid the center of the axle, and maked in on the frame rails. Both sides of the rail, on both PS and DS frame rails. I then welded in the notch, and transfered the line before cutting the frame section out. It turned otu fine, the ale is centered in the notch layed out, and about 3/16" back around 5-6" lift.
