Toyota Trucks \  weber carbs
weber carbs
Toyota Trucks Make Specific
views 292
replies 6
following 5
LWENUF   +1y
hi everyone i have a 93 toyota pickup i had 40 dcoe bebers on it and got some new crhome 45 dcoe webbers my problem is that when i start it it idles like at 3 grand i dont know why any help would be great thanks.
bdroppeddak   +1y
turn the idle screw down
LWENUF   +1y
i turned it all the way down it didnt do anything
iceman9669   +1y
start it and then once it runs for like 2-3 seconds then just tap the accelerator pedal(gas pedal) make sure it revs up when you tap it though, b/c on my yota it does the same... so just tap the gas pedal and it should go back to normal throttle postion
oldschool   +1y
if the idle screw didnt do anything you need to check that your linkage isnt binding up somewhere, even if it moves freely it might not allow full movement, try unhooking the linkage and then start it and see how it runs then.
oldschool   +1y
Edited: 5/5/2006 3:43:41 AM by oldschool
also check out http://www.webercarburetors.com
LWENUF   +1y
i think i found the problem one of the idle mixture screws broke all the way inside of the carb so now i got to send it in to lc engeniring to get repaired thanks for everyones help.
