Isuzu \  driveshaft clearance
Isuzu Make Specific
views 320
replies 7
following 8
microscopic   +1y
i went from 16s to 18s and i already had to cut out the rear section of the cab for the driveshaft to clear and since i put the 18s on the driveshaft hits all sorts of nasty what do i do to fix th problem
whynotfab   +1y
Suicidedoors sells driveshaft tunnels, saw them in a recent MT.. different lenghts I think and should work
minipu95   +1y
this is true!
mmrcustoms   +1y
i just need to cut the cacb in the back and make one around a big pipe
draginzuzu   +1y
get a driveshaft from a 2wd rodeo its 2 piece, Thats what I used and didnt have to cut the cab at all, just have to make a carrier bearing support, no big deal
opie90   +1y
You may have to cut it or extend it. Or go to any good driveline shop and have it turned into a 2 piece shaft
blazed22s   +1y
notch the driveshaft.... j/k!
slamsuzu   +1y
Take out the seat and cut out the cab. Patch it back up with a tunnel or get some steel and make a tunnel yourself. Its real easy to do.
