suicidedoor86
You wanna lay the front crossmember and the gas tank on the ground?Because thats essentially where the astro will stop -short of a bodydrop of course.To sit on the tank and member on 20's you need drop spindles,no swaybar,probably need to notch for the tie rods,a frame notch in the rear for sure,cut out front wheelwells and probably some rear tubwork too.To bodydrop on 20's you need to ditch the front wheelwells alltogether or move them up higher and you would have to cut into your footroom in the interior for sure too.Would also need custom control arms for more drop I would imagine.A larger notch in the rear for sure.Depending on how you bodydrop it(channel or stock floor)you may need custom crossmembers, a relocated gas tank,dropped motormounts,cut tunnel for transmission and mega tubwork in the rear,also a narrowed rear end.You would have to z the front frame in a stock floor too.
