installing 2 piece driveshaft question
Marshkid1@charter.net's avatar
Marshkid1's avatar
Marshkid1
I built a carrier bearing support. Just wondering if anyone knows what the first drive piece off the trans needs for a pinion angle, or if it should be just straight back? thanks guys-mike
Kyrasis6's avatar
Kyrasis6
I don't know if I understand what you mean by this, I think pinion angle needs to be between around 1-3 degrees, up to 5 is safe but the higher the pinion angle the more stress it will be under at higher rpms. At 5 degrees or more you will have relatively large power loses and the u-joints may not hold together at around 5,000 rpm.
laynwindows
i've had 2 93's. 1 x cab and 1 standard, and both have had 2 piece drive shafts. my 79 has a one piece.
nascarguy3's avatar
nascarguy3
I have an x-cab with a 2 piece shaft and I run a mono leaf now and I am at 4 degrees and I drive 600 miles aweek on it and no noise yet..
