Air Ride Suspensions \  Valve placement...
Valve placement...
Air Ride Suspensions Q & A
views 170
replies 6
following 5
thacru78   +1y
I want to put my valves at the bags. I want to run a tee straight off the bag, have the fill on one side and the dump on the other. Of course have the line coming into the fill valve. My question is will the be ok. I know sometimes when the air transfers it will cause the airline to flex. Will this flex cause problem with my fiting leaking. Anyone set it up like this and had problems. Thanks
thacru78   +1y
36 views and no comment. This isn't a stupid question is it.....
Tuknkrome   +1y
i used to have that set up and i had problems with it.
Rusty Shackleford   +1y
currently runnin that kinda setup in the rear of my taco. valves connected to the baggs. nice and LOUD with no problems.
Dupa102933   +1y
i run that setup on the front and rear of my truck.......not a problem yet
thacru78   +1y
What type of line are you running with that setup. I am going to run hydraulic line so it will be pretty stiff so it might not flex much. I just don't want leaky valves all the time. Thanks for the input. Anymore
mine is 1/2 air. hardline should be fine if not better
